At the risk of starting a war on a Friday, I want to try to use UH to crowd-source some information about features available in various engines. For each of the following features, I am looking for one answer per engine and each answer to consist of a list of yes/no/partial/user-hook to the ability to model each of the following. Feel free to append to the list if you want to expand scope.
- Dedicated outdoor air systems (DOAS)
- Variable refrigerant flow (VRF) systems
- Variable-speed drives
- Commercial refrigeration
- Air-source heat-pump
- Water-source heat-pump
- Ground-source heat-pump
- Multi-function heat-pump
- Radiant heating
- Radiant cooling
- Evaporative cooling
- Absorption chiller
- Condensing boiler
- Heat recovery
- Ice storage
- Equipment cycling
- Optimal start/stop
- Static pressure reset
- User defined control
- Photo-voltaics
- Building integrated photo-voltaics
- Solar thermal
- Natural ventilation
- Displacement ventilation
- Underfloor air distribution
- Illuminance calculations (i.e., virtual sensors)
- Illuminance calculation-driven lighting control
- Illuminance calculation-driven shade/blind control
- Thermal mass
- Thermal bridges
- Phase-change-material
