When using energy simulation (such as EnergyPlus) for load calculation, which averaging window do you choose to calculate the peak load that will determine the size of your HVAC systems?
I am specially concerned with those cases where you have thermostat schedules with night setup or setback for the design day and you'll get much higher peak values the shortest the time you average the loads. Do you design with different averaging times depending on the project? That is, you choose that one type of project can admit one hour to reach the setpoint while other may need a shorter period?
Which approach do you use? Please, share your thoughts.
