as an output , I am looking at the HPWHPLANTTANK:Water Heater Use Side Heat Transfer Rate W to find out the heat withdrawn from my water heater tank. I can't understand the huge spikes in some points.
| 1 | initial version |
| 2 | No.2 Revision |
as an output , I am looking at the HPWHPLANTTANK:Water Heater Use Side Heat Transfer Rate W[W](Hourly) to find out the heat withdrawn from my water heater tank.
| 3 | No.3 Revision |
