Good evening, I have a problem in sketchup. When I add two elements of stratigraphy in .idf file in IDF editor in "Construction", and then check this stratigraphy to items within SketchUp in "BuildingSurface: Detailed" and I try to download the file from SketchUp .idf me disappear the building. Why?
NOTE: The problem occurs only when you check "Construction" in "BuildingSurface: Detailed"
I created a video explaining the problem.
Thanks for the support
http://tinypic.com/player.php?v=10z3jpd%3E&s=9#.VkOACFXhDIV
