asked 9 years ago
ngkhanh's avatar
performance input for DOAS DX coil
Hello, I am trying to get DOAS DX coil working while i get low flow rate /W cooling. However, it frequently fault because of auto sizing process so i am thinking about hardsizing but i have never done it before. Please someone had done it show me a typical way to pass this step. Everytime i try DOAS option in coilsystem:dx cooling get fatal error. Thanks
click to hide/show revision 2
No.2 Revision
Hello, I am trying to get DOAS DX coil working while i get low flow rate /W cooling. However, it frequently fault because of auto sizing process so i am thinking about hardsizing but i have never done it before. Please someone had done it show me a typical way to pass this step. Everytime Every time i try DOAS option in coilsystem:dx cooling get fatal error. error. Note: i checked TRANE TRACE Library and saw similar curve in their library. Are they can use as input for E+ ? Have any people tried to do like this before ? Thanks
Hello, I am trying to get DOAS DX coil working while i get low flow rate /W cooling. However, it frequently fault because of auto sizing process so i am thinking about hardsizing but i have never done it before. Please someone had done it show me a typical way to pass this step. Every time i try DOAS option in coilsystem:dx cooling get fatal error. Note: i checked TRANE TRACE Library and saw similar curve in their library. Are they can use as input for E+ ? Have any people tried to do like this before ? Thanks
click to hide/show revision 5
No.5 Revision
Hello, I am trying to get DOAS DX coil working while i get low flow rate /W cooling. However, it frequently fault because of auto sizing process so i am thinking about hardsizing but i have never done it before. Please someone had done it show me a typical way to pass this step. Every time i try DOAS option in coilsystem:dx cooling get fatal error. Note: i checked TRANE TRACE Library and saw similar curve in their library. Are they can use as input for E+ ? Have any people tried to do like this before ? Here is my link : https://www.dropbox.com/s/h18xs3y7fht9ziy/DOASDXCOIL_wADPBFMethodDCV5outdoortest2EMS1.idf?dl=0. It get fault with sizing period. If you enable DOAS option it will get fatal error, it was mentioned in Energyplus mailing list. if i keep like this, the DOAS coil wil be kept at normal rate limit which is less than 12 kW gross rate and not able to suply dry enough air - the main advantage of DOAS. Thanks
click to hide/show revision 6
No.6 Revision
Hello, I am trying to get DOAS DX coil working while i get low flow rate /W cooling. However, it frequently fault because of auto sizing process so i am thinking about hardsizing but i have never done it before. Please someone had done it show me a typical way to pass this step. Every time i try DOAS option in coilsystem:dx cooling get fatal error. Note: i checked TRANE TRACE Library and saw similar curve in their library. Are they can use as input for E+ ? Have any people tried to do like this before ? ?
Here is my link : https://www.dropbox.com/s/h18xs3y7fht9ziy/DOASDXCOIL_wADPBFMethodDCV5outdoortest2EMS1.idf?dl=0. https://www.dropbox.com/s/h18xs3y7fht9ziy/DOASDXCOIL_wADPBFMethodDCV5outdoortest2EMS1.idf?dl=0 It get gets fault with sizing period. If period.If you enable DOAS option it will get fatal error, it was mentioned in Energyplus mailing list. if i keep like this, the DOAS coil wil be kept at normal rate limit which is less than 12 kW gross rate and not able to suply dry enough air - the main advantage of DOAS. Thanks
