Hi all
I'm looking for some help about a problem I have with Energy Plus, I'm trying to run a simulation using a BSDF-window system that I created with Window 7, but I get this error msg:
* Severe * Window tarcog returned an error * ~~~ * message = "Tarcog failed to converge" During Warmup, Environment=RUN PERIOD 1, at Simulation time=01/01 00:15 - 00:30 * ~~~ * surface name = G1UP * ~~~ * construction name = CF_GLZ_75
That I guess refers to the field corresponding to FenestrationSurface:Detailed and located in the Thermal zones and surfaces (to reference it to the BSDF-IF file):
Thermal Zones and Surfaces --> [0006] FenestrationSurface: Detailed --> Name: g1up; Surface type: window; Construction Name: CF_Glz_75;
I'm using the editor so I'm also adding details from the BSDF-IDF file to: Construction:ComplexFenestrationState and Matrix:TwoDimensions
I thought at first that it was a problem with the version of Energy Plus but previous and the current version give the same error.
I'd appreciate your help.
Thanks
Ch.
