In OpenStudio plugin 1.9.0 when you project a loose door, it will be automatically defined as a glass door, and this type of fenestration has no construction in the IDF model.
Previously, it was by default a door (with an assigned construction) and we knew that, it's better not set it to glass door in OS. I don't why they have made it the default door type, without assigning a construction to it.
