Are there any web-based APIs that can accept IDF file as input and return the 3D geometry view of IDF files?
The view should have the similar behavior as SketchUp, such as Zoom in/out, rotate, move.
| 1 | initial version |
| 2 | No.2 Revision |
Are there any web-based APIs that can accept IDF file as input and return the 3D geometry view of IDF files? So I can put the results in an
and used in my website. | 3 | No.3 Revision |
| 4 | No.4 Revision |
Are there any web-based APIs that can accept IDF file as input and return the 3D geometry view of IDF files? So I can put the results into my website.
It will be great if the view can have the similar behavior as SketchUp, such as Zoom in/out, rotate, move.move.
I mean web-based APIs, so the return should be in HTML format.
| 5 | retagged |
