Is there a way to disable the 'autosave' in the sketchup plugin? I've got a hotkey so I can save quickly regularly and the autosave's timing is impeccable/annoying/not ideal....thanks in advance.
| 1 | initial version |
| 2 | No.2 Revision |
Is there a way to disable the 'autosave' in the sketchup plugin? I've got a hotkey so I can save quickly regularly and the autosave's timing is impeccable/annoying/not ideal....thanks in advance.ideal...
| 3 | No.3 Revision |
Is there a way to disable the 'autosave' in the sketchup plugin? I've got a hotkey so I can save quickly regularly and the autosave's timing is impeccable/annoying/not annoying/not ideal...
| 4 | retagged |
Is there a way to disable the 'autosave' in the sketchup plugin? I've got a hotkey so I can save quickly regularly and the autosave's timing is annoying/not ideal...
