I would like to use AEDG Small to Medium Office - SlabAndBasement for correct ground coupling in Openstudio. However, I am modelling in SI units. So, I was wondering if I can use the mesures. I tried it and it was running perfectly. Instead of putting slab area to perimeter ratio in ft2/ft I put the value in m2/m. Thanks for your advice.
