Are there any hard/set limits on the number of spaces, zones, systems, or etc for either OpenStudio [both the Sketchup Plug In and the OS Application] or for EnergyPlus? Or is this more limited by the computing power of the machine you are using? Is there any straightforward way [if necessary] to allocate more resources for larger models? I haven't come across a solid answer and was interested to see what was known by others. Thanks in advance.
