Whenever I try to view the diagram of the 'Hot Water Loop' OpenStudio 1.9.0 crashes. I believe this may be attributed to amount of components I have assigned to the loop, but I'd like verification that this is the case. If so, is there a work around that would allow to still have the same amount of equipment?
The model can be found here and is a work in progress at a very early stage.
https://www.dropbox.com/s/y9zvbr2bpik4kcj/BerthoudHall.osm?dl=0
Thanks.
