Hello Again, everything works fine so far, but as I now want to get the illuminance in a room I followed the radiance_tutorial and end up in the following problem: When I use the provded sky.rad and create the sky.mat using gensky as described in the tutorial, I result in the following:
$ echo 0 0 0 0 0 1 | rtrace -I -ab 1 octrees\sky.oct
#?RADIANCE
oconv skies\sky_10klx.mat skies\sky.rad
rtrace -I -ab 1
SOFTWARE= RADIANCE 4.2a lastmod by on w015t-001
CAPDATE= 2015:09:15 11:56:42
GMT= 2015:09:15 09:56:42
FORMAT=ascii
4.751300e+001 5.813355e+001 6.707717e+001
and
echo 0 0 0 0 0 1 | rtrace -I -h -ab 1 octrees\sky.oct | rcalc -e "$1=179(.265$1+.670$2+.065$3)"
10025.4983
This is as near as I can get, but the sky is not grey. Can anyone provide me with an answer? Thanks, Fabian
