I've been trying to use the runenergyplus shell script but keep getting an error.
So I have an IDF file and a weather file and do:
runenergyplus idffile weather_file
which runs all the calculations but then I get this:
Writing tabular output file results using HTML format.
Computing Life Cycle Costs and Reporting
Writing final SQL reports
EnergyPlus Run Time=00hr 00min 15.69sec
ReadVarsESO program starting.
Requested ESO file=eplusout.eso
does not exist. ReadVarsESO program terminated.
Requested ESO file=eplusout.mtr
Started HVAC Diagram
Complete
Isn't running runenergyplus supposed to create the .eso file that is missing? In the output folder I'm still getting the following:
- .audit
- .bnd
- .eio
- .err
- .expidf
- .mdd
- .mtd
- .rdd
- .rvaudit
- .shd
- .sql
- .svg
- SQLite.err
- .html
- .csv
