Hey, I am trying to use Eppy for the first time and I have a question (from the Tutorial) regarding :
- iddfile = "../eppy/resources/iddfiles/Energy+V7_2_0.idd"
- fname1 = "../eppy/resources/idffiles/V_7_2/smallfile.idf"
As I understand, the idd file is an input data dictionary file which contains a list of all possible EnergyPlus objects and a specification of the data each object requires. So the .idd file is the same for all projectes, right? So shound i create a new file (in the Tutorial) iddfile, or should i set the path to " C:\EnergyPlusV8-1-0\Energy+.idd"? Thank you for your help!
