when i create OpenStudio measures, i find it is possible to create Energyplus measure? How do i implement the Energyplus measure? Do i need to run the E+ measure through OpenStudio, which will finish the desired task in the back? Or do i need to import the E+ measure into energyplus to do the desired task?
