Hi Again, I would like to run GenOpt in our server. The simulator is Matlab. I can run it without any problem in PC with the command line in the configuration file like below: Command = "cmd /c \"\"C:\Program Files\MATLAB\R2012a\bin\\"matlab -wait -nodisplay -nosplash -nodesktop -r \"addpath('C:\Users\jesmanim\Documents\genopt\example\quad\5_spot_1producer');decoder_5spot %Simulation.Files.Log.Path1%;exit\"\"";
However, when I run it in the server with the command line:
Command ="matlab -nodisplay -nosplash -nodesktop -r \"addpath('/home/jesmanim/ code/genopt/example/quad/5_spot');decoder_5spot(%Simulation.Files.Log.Path1);exi t;\"";
It seems GenOpt is waiting for Matlab and nothing works there. Is there any idea?
