In OpenStudio 1.8.5 I cannot use the measure "Set Output Table to IP Units" without the program failing on runs. I believe this is because OS 1.8.5 (and possibly 1.9) have the measure "OpenStudio Results" built in which requires the output file to be in SI units. Is there a way in OS 1.8.5 to either get the EnergyPlus results in IP units using a measure or to turn off the built in OpenStudio results?
