hello i have this problem with Sketchup and Openstudio 6bit on window 7 sp1
Error Loading File C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/OpenStudio/Startup.rb
Error: #<encoding::converternotfounderror: code="" converter="" not="" found="" (utf-16le="" to="" windows-1258)>="" c:="" program="" files="" openstudio="" 1.8.5="" ruby="" openstudio="" sketchup_plugin="" lib="" pluginuserscriptrunner.rb:261:in="" <code="">glob'
C:/Program Files/OpenStudio 1.8.5/Ruby/openstudio/sketchup_plugin/lib/PluginUserScriptRunner.rb:261:indiscover_user_script_directory'
C:/Program Files/OpenStudio 1.8.5/Ruby/openstudio/sketchup_plugin/lib/PluginUserScriptRunner.rb:299:in discover_user_scripts'
C:/Program Files/OpenStudio 1.8.5/Ruby/openstudio/sketchup_plugin/lib/PluginManager.rb:155:instart'
C:/Program Files/OpenStudio 1.8.5/Ruby/openstudio/sketchup_plugin/lib/PluginManager.rb:520:in <module:OpenStudio>'
C:/Program Files/OpenStudio 1.8.5/Ruby/openstudio/sketchup_plugin/lib/PluginManager.rb:67:in<top (required)>'="" c:="" programdata="" sketchup="" sketchup="" 2015="" sketchup="" plugins="" openstudio="" startup.rb:45:in="" <code="">load'
C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/OpenStudio/Startup.rb:45:in<top (required)>'="" c:="" program="" files="" sketchup="" sketchup="" 2015="" tools="" extensions.rb:197:in="" <code="">require'
C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:inload'
C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/OpenStudio.rb:167:in register_extension'
C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/OpenStudio.rb:167:in<top (required)>'<="" p="">
Someone helps me pls Thanks
