I'm using energyplus to simulate a data center. CRAC units with correspondingly high capacities often have 2 stages. So I 'm using the coil object "Coil:Cooling:DX:TwoStageWithHumidityControlMode". Is it necessary to set the "Enhanced Dehumidification Mode" to 1 for the control types "CoolReheat" and "Multimode"? Or this both paramters independently of each other? Furthermore I'm not sure which control typ is the right one for typical CRAC units?
