I want to model a tank-style condensing domestic water heater.
It seems that the EnergyPlus WaterHeater:Mixed only accepts a quadratic curve, function of Part Load Ratio (PLR) only, whereas a biquadratic curve function of PLR and return water temp is warranted.
So I'd tend to go ahead and use a Boiler:HotWater and a WaterHeater:Mixed for which I'd at least put the Heater Maximum Capacity to zero to simulate a simple storage tank.
Should I put the boiler and the tank in series on one supply branch?
What parameters for the WaterHeater:Mixed should I use, especially Deadband temperature, control type?
What kind of setpoint managers and availability managers and where?
Any example of a working setup would be much appreciated.
