Hi All,
I am also trying to use the ConductionFiniteDifference method in one test case I am running. Is there a way to know the error tolerance which is used to control convergence when using this method? Is the error tolerance applied to all variables or to a specific variable? If the latter, then I would like to know the variable which is used as well as the error tolerance value.
Thanks a lot!
Thierry
