Simulation failed when building has a glassdoor
I have tested OS without using WWR scrip, simple building in image below. By default, from version 1.6 (may be wrong) OS set a rectangle that touch the bottom of each level as glassdoor and then simulation failed. Changing glass door to fix windows can fix this issue, E+ run fine. (I use VRF system in this case. OS 1.8.5) I think there are something wrong when OS translates glassdoor into E+.
EDIT
Here is the eplus.erreplusout.err
Program Version,EnergyPlus, Version 8.3.0-6d97d074ea, YMD=2015.09.15 16:36,IDD_Version 8.3.0
************* IDF Context for following error/warning message:
************* Note -- lines truncated at 300 characters, if necessary...
************* 785 FenestrationSurface:Detailed,
************* indicated Name=Sub Surface 1
************* Only last 3 lines before error line shown.....
************* 786 Sub Surface 1, !- Name
************* 787 GLASSDOOR, !- Surface Type
************* 788 , !- Construction Name
** Severe ** IP: IDF line~788 Error detected in Object=FENESTRATIONSURFACE:DETAILED, name=SUB SURFACE 1
** ~~~ ** Field [Construction Name] is required but was blank
** Warning ** IP: Note -- Some missing fields have been filled with defaults. See the audit output file for details.
** Severe ** IP: Blank "required" fields found in input
** Severe ** IP: Out of "range" values and/or blank required fields found in input
** Fatal ** IP: Errors occurred on processing IDF file. Preceding condition(s) cause termination.
...Summary of Errors that led to program termination:
..... Reference severe error count=3
..... Last severe error=IP: Out of "range" values and/or blank required fields found in input
************* Warning: Node connection errors not checked - most system input has not been read (see previous warning).
************* Fatal error -- final processing. Program exited before simulations began. See previous error messages.
************* EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors.
************* EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors.
************* EnergyPlus Terminated--Fatal Error Detected. 1 Warning; 3 Severe Errors; Elapsed Time=00hr 00min 0.23sec
