If I draw two or more separate thermal zones in the space with the different thermophysical properties of the walls (radiance and reflectance), open studio simulates the interaction of this properties between the zones?
| 1 | initial version |
| 2 | No.2 Revision |
| 3 | retagged |
| 4 | No.4 Revision |
If I draw two or more separate thermal zones in the space with the different thermophysical properties of the walls (radiance and reflectance), open studio OpenStudio simulates the interaction of this properties between the zones?
