How to remove solar water heater from Title 24 Calcs
I am working on a project that is pursuing Title 24 2013 and I'm using CBECC-Com 2013-3b. The reviewer indicated that since the project is pursuing the solar ready path instead of installing solar water heaters, that solar water heater needs to be removed from Title 24 calculations.
Does anyone know how to do this? Alternatively, do I have to export to EnergyPlus to make this change?
