heating energy when changing cooling setpoint temperature
 Hello,
 Anyone knows why heating load changes a lot when I only change cooling setpoint temperature? Theoretically, it should not be influenced.
 By the way, in In my model, what i use is Standard VAV-Reheat created from HVACTemplate objects. objects is used. The thermostat for heating is 20C, and the one for cooling varies from 20C to 26C.
 Anyone knows why heating load changes a lot when I only change cooling set point temperature? Theoretically, it should not be influenced. Maybe because of the Reheat?
 By the way, in Thermostat: DualSetpoint, is that possible that cooling set point and heating set point are the same? If not,  what is the deltaT at least?
 Thanks =)
