May I ask if EnergyPlus can output the temperature of the air around the outside of surface?
Is it the same as the outside surface temperature?
I ask this is because I'm trying to model a PV panel as a shading surface put above the roof surface in close distance. I want to know if the temperature of the air between the PV panel and the roof surface is hot enough to affect the output efficiency of the PV panel, assuming a certain desired temperature range for optimal PV output.
Thanks!
