I have a model that will not run in PAT but runs just fine in OS. I am not sure what could be causing the issue. I receive the following error when uploading the baseline in PAT. This occurs on 3 different computers using different versions of OS and PAT.
The model is fairly simple and included the AMY weather file for 2014. A zipped copy can be found at: https://www.dropbox.com/s/rcdl2ynt5e8ol7f/FGMatt.zip?dl=0
Thank you.
