Hey, there is no default value in loads/temperature convergence tolerance. Tutorials recomment: for temperature (.4 default); loads tolerances (.04 default). In the most example files there is a Temperature covergence Tolerance of 0,005, with this value i get the follwing severe:
* Severe * CheckWarmupConvergence: Loads Initialization, Zone="zone1" did not converge after 25 warmup days. * ~~~ * See Warmup Convergence Information in .eio file for details. * ~~~ * ...Environment(RunPeriod)="GRAZ - AUT IWEC Data WMO#=112400" * ~~~ * ..Max Temp Comparison = 0.22 vs Temperature Convergence Tolerance=5.00E-003 - Fail Convergence * ~~~ * ..Min Temp Comparison = 0.21 vs Temperature Convergence Tolerance=5.00E-003 - Fail Convergence
Is a temperature convergence tolerance of 0,4 a proper value? Thank you very much!!
