I am trying to set up an optimization run with JEPLUS+EA using RVX. However, I do not understand what the option scaling means in the objective definition. I have read it several time in the JEPLUS help but cannot get a clue. Maybe because I am not a programmer. Can anyone explain it in simple words or using an example? Thanks a lot.
I attach the code from the example file. Why is scaling true for the first objetive but not for the second?
"objectives" : [
"identifier" : "t1",
"formula" : "v0/1000/3600",
"caption" : "Electricity [kWh]",
"scaling" : true,
"min" : 0,
"max" : 100000,
"weight" : 1.0
"identifier" : "t2",
"formula" : "v2",
"caption" : "Construction Cost [$/m2]",
"scaling" : false,
"min" : 0,
"max" : 1000,
"weight" : 1.0
