How to add Phase Change Material to open studio?
Hello, I have been trying to add PCM to wall in my openstudio model using a measure from BCL, I used two measures both give the same error message "SWIG director type mismatch in output value of type 'bool'"
I have tried to add a material with phase change properties from material tab but I couldn't find anyone in my library. Also tried to edit the xml file of the measure to make the default values as I need in a way to help ignore this error when I run simulation with "classic CLI" checked, but of no use. Can anyone help?
