In sketchbox If i have multiple EEM, in one run, does the output result spreadsheet show energy savings for each individual EEM as if each EEM is applied one at a time, or does it include interactive effects of prior EEM. For example, my cooling equipment EEM is 6th from the top in the EEM set, will it show the energy saving of only cooling equipment kw/ton reduction or other items such as lighting EEM which is number 3 from the top.
