Open Studio - "Heating coil air heating energy" error
Hi, I am getting this error which running simulation. I am not sure what changed cause the simulation was running fine previously. The error started showing after Rated Total Heating Capacity is Hard Sized.
Can someone please help me understand what does this error mean?
* Severe * Invalid Output:Variable or Output:Meter Name =HEATING COIL AIR HEATING ENERGY * ~~~ * Entered in EnergyManagementSystem:Sensor=ENERGY_MANAGEMENT_SYSTEM_SENSOR_33 * ~~~ * Output:Variable Name not found * Fatal * Errors found in processing Energy Management System input. Preceding condition causes termination. ...Summary of Errors that led to program termination: ..... Reference severe error count=3 ..... Last severe error=Invalid Output:Variable or Output:Meter Name =HEATING COIL AIR HEATING ENERGY *** Warning: Node connection errors not checked - most system input has not been read (see previous warning). *** Fatal error -- final processing. Program exited before simulations began. See previous error messages.
** Severe  * ** Invalid Output:Variable or Output:Meter Name =HEATING COIL AIR HEATING ENERGY
 * **   ~~~   * ** Entered in EnergyManagementSystem:Sensor=ENERGY_MANAGEMENT_SYSTEM_SENSOR_33
 * **   ~~~   * ** Output:Variable Name not found
 * **  Fatal  * ** Errors found in processing Energy Management System input. Preceding condition causes termination.
 *** ************* Warning:  Node connection errors not checked - most system input has not been read (see previous warning).
 *** ************* Fatal error -- final processing.  Program exited before simulations began.  See previous error messages.messages.
Thank you!
** Severe  ** Invalid Output:Variable or Output:Meter Name =HEATING COIL AIR HEATING ENERGY
**   ~~~   ** Entered in EnergyManagementSystem:Sensor=ENERGY_MANAGEMENT_SYSTEM_SENSOR_33
**   ~~~   ** Output:Variable Name not found
**  Fatal  ** Errors found in processing Energy Management System input. Preceding condition causes termination.
Thank you!
