I got this error while running radiance measure in OpenStudio
Standard Output:
[38;2;255;165;000m┌────────────────────────────────────────────────────────────────────────────────┐
│ The classic command is deprecated and will be removed in a future release │
└────────────────────────────────────────────────────────────────────────────────┘[0m
[02:20:00.806231 ERROR] Perl could not be found in path, exiting
Error executing argv: ["run", "-m", "-w", "C:/Users/sandi/AppData/Local/Temp/osmodel-2049-7891-d182-cf37-1767773408-0/ApplyMeasureNow/temp.osw"]
Error: exit in C:/Users/sandi/BCL/1e3cfef8-b051-4e60-8bb0-ed2d29d4f45f/602e0b93-8ed6-4479-821c-87092fc26ef8/measure.rb:497:in exit'
C:/Users/sandi/BCL/1e3cfef8-b051-4e60-8bb0-ed2d29d4f45f/602e0b93-8ed6-4479-821c-87092fc26ef8/measure.rb:497:inrun'
:/ruby/3.2.0/gems/openstudio-workflow-2.4.0/lib/openstudio/workflow/util/measure.rb:487:in apply_measure'
:/ruby/3.2.0/gems/openstudio-workflow-2.4.0/lib/openstudio/workflow/util/measure.rb:84:inblock in apply_measures'
:/ruby/3.2.0/gems/openstudio-workflow-2.4.0/lib/openstudio/workflow/util/measure.rb:37:in each_index'
:/ruby/3.2.0/gems/openstudio-workflow-2.4.0/lib/openstudio/workflow/util/measure.rb:37:inapply_measures'
:/ruby/3.2.0/gems/openstudio-workflow-2.4.0/lib/openstudio/workflow/jobs/run_os_measures.rb:40:in perform'
:/ruby/3.2.0/gems/openstudio-workflow-2.4.0/lib/openstudio/workflow/run.rb:261:instep'
:/ruby/3.2.0/gems/openstudio-workflow-2.4.0/lib/openstudio/workflow/run.rb:203:in run'
:/openstudio_cli.rb:1197:inexecute'
:/openstudio_cli.rb:827:in execute'
:/openstudio_cli.rb:1994:in'
eval:236:in eval'
eval:236:inrequire_embedded_absolute'
eval:221:in block in require_embedded'
eval:215:ineach'
eval:215:in require_embedded'
eval:174:inrequire'
eval:3:in `'
Standard Error:
run.log: [02:20:00.806231 ERROR] Perl cou
