Workaround for Fatal Pump Error in CBECC-Com v3c
I'm getting the following EP fatal error when running a CBECC-Com v3c model.
**  Fatal  ** ManagePumps: Invalid PumpIndex passed=3, Pump name={2F8F93D1-99C6-4687-8A38-3D2977F628F6}, stored Pump Name for that index=PUMP HWCP-1
It appears that the Pump object Name field is being replaced with a UUID from a Node causing a fatal error in EP here.
OS:Pump:VariableSpeed,
  {6f91d1f9-8020-4396-a564-5b2f208c7497}, !- Handle
  => {2f8f93d1-99c6-4687-8a38-3d2977f628f6}, !- Name
  {b38eb438-d964-42a4-8929-ed73d3aef2d7}, !- Inlet Node Name
  {7b03fee8-03ef-458c-b3ed-f4b587a2cdd0}, !- Outlet Node Name
  ,                                       !- Rated Flow Rate {m3/s}
  0,                                      !- Rated Pump Head {Pa}
  ,                                       !- Rated Power Consumption {W}
  ,                                       !- Motor Efficiency
  ,                                       !- Fraction of Motor Inefficiencies to Fluid Stream
  ,                                       !- Coefficient 1 of the Part Load Performance Curve
  ,                                       !- Coefficient 2 of the Part Load Performance Curve
  ,                                       !- Coefficient 3 of the Part Load Performance Curve
  ,                                       !- Coefficient 4 of the Part Load Performance Curve
  ,                                       !- Minimum Flow Rate {m3/s}
  Intermittent;                           !- Pump Control Type
OS:Node,
  {cc6db6d4-1301-4fcb-a556-d38086c9bd58}, !- Handle
  => {2f8f93d1-99c6-4687-8a38-3d2977f628f6} Outlet Node, !- Name
  {7b03fee8-03ef-458c-b3ed-f4b587a2cdd0}, !- Inlet Port
  {1cc159bd-0dcc-477b-a250-4a313c9b8468}; !- Outlet Port
It appears that the Pump object Name field is being replaced with a UUID from a Node causing a fatal error in EP here. (see => below).
OS:Node,
I'm getting the following EP fatal error when in EP after running a v3 CBECC-Com v3c model.model (generated from IES VE) in v3c.
It appears that the Pump object Name field is being replaced with a UUID from a Node causing a fatal error in EP here (see => below).
OS:Node,
I'm getting the following fatal error in EP after running a v3 CBECC-Com model (generated from IES VE) in v3c.
XML FILE
OS:Node,
XML FILE
OS:Node,
ADDITIONAL INFO ABOUT THE CAUSE OF THE ERROR
User-defined SHW Pump
OSM Showing Pump Added by User
OSM Showing Pump added by CBECC-Com v3c
XML FILE
OS:Node,
