Question About EMS:Sensor and People with Space/SpaceList in EnergyPlus 23.1+
Hello everyone,
I am migrating a model to EnergyPlus v25.1 and have an indexing issue with an EMS:Sensor.
Previously, in v9.4, when the People object pointed to a Zone, the EMS sensor used the People Object Name as the index key, and it worked:
PEOPLE,
    People PlantaX08:Office,    !- Name
    PlantaX08:Office,         !- Zone or ZoneList Name
ENERGYMANAGEMENTSYSTEM:SENSOR,
    PMV_PlantaX08_Office,     !- Name
    People PlantaX08:Office,    !- OutputVariable or OutputMeter Index Key Name (People Object Name)
    Zone Thermal Comfort Fanger Model PMV;
Now, in v25.1, my People object points to a SpaceList:
People,
  Residential Living Occupants,           !- Name
  Residential - Living Space,             !- Zone or ZoneList or Space or SpaceList Name (SpaceList)
When I try to use the People Object Name (Residential Living Occupants) as the index key for the Zone Thermal Comfort Fanger Model PMV variable, I get a Severe Error:
Severe Invalid Output:Variable or Output:Meter Index Key Name = RESIDENTIAL LIVING OCCUPANTS
So, my question is: What should be the value for the OutputVariable or OutputMeter Index Key Name field now?
    PMV_whatever,     !- Name
    ????????,    !- OutputVariable or OutputMeter Index Key Name
The relevant objects in the idf for this issue are:
People,
  Residential Occupancy Schedule,         !- Number of People Schedule Name
  People/Area,                            !- Number of People Calculation Method
  0.025,                                  !- People per Floor Area {person/m2}
  ,                                       !- Floor Area per Person {m2/person}
  0.3,                                    !- Fraction Radiant
  0.5,                                    !- Sensible Heat Fraction
  Residential Activity Schedule,          !- Activity Level Schedule Name
  ,                                       !- Carbon Dioxide Generation Rate {m3/s-W}
  Yes,                                    !- Enable ASHRAE 55 Comfort Warnings
  ,                                       !- Mean Radiant Temperature Calculation Type
  ,                                       !- Surface Name/Angle Factor List Name
  Always On Discrete,                     !- Work Efficiency Schedule Name
  ,                                       !- Clothing Insulation Calculation Method
  ,                                       !- Clothing Insulation Calculation Method Schedule Name
  Always On Discrete,                     !- Clothing Insulation Schedule Name
  Always On Discrete,                     !- Air Velocity Schedule Name
  Fanger;                                 !- Thermal Comfort Model 1 Type
SpaceList,
  Residential - Living Space,             !- Name
  Floor_1,                                !- Space Name 1
  Floor_2;                                !- Space Name 2
Space,
  Floor_1,                                !- Name
  Floor_1_Zone,                           !- Zone Name
  ,                                       !- Ceiling Height {m}
  ,                                       !- Volume {m3}
  ,                                       !- Floor Area {m2}
  Residential - Living Space;             !- Space Type
Space,
  Floor_2,                                !- Name
  Floor_2_Zone,                           !- Zone Name
  ,                                       !- Volume {m3}
Zone,
  Floor_2_Zone,                           !- Name
  ,                                       !- Direction of Relative North {deg}
  0,                                      !- X Origin {m}
  0,                                      !- Y Origin {m}
  0,                                      !- Z Origin {m}
  ,                                       !- Type
  1,                                      !- Multiplier
  ,                                       !- Volume {m3}
  ,                                       !- Zone Inside Convection Algorithm
  ,                                       !- Zone Outside Convection Algorithm
  Yes;                                    !- Part of Total Floor Area
Zone,
  Floor_1_Zone,                           !- Name
  0,                                      !- X Origin {m}
  0,                                      !- Y Origin {m}
  0,                                      !- Z Origin {m}
  ,                                       !- Type
  1,                                      !- Multiplier
  ,                                       !- Volume {m3}
Hello everyone,
Previously, in v9.4, when the People object pointed to a Zone, the EMS sensor used the People Object Name as the index key, and it worked:worked:
PEOPLE,
People,
People,
SpaceList,
Space,
  Floor_1,                                !- Name
  ,                                       !- Volume {m3}
Space,
  Floor_2,                                !- Name
  ,                                       !- Volume {m3}
Zone,
  0,                                      !- X Origin {m}
  0,                                      !- Y Origin {m}
  0,                                      !- Z Origin {m}
  ,                                       !- Type
  1,                                      !- Multiplier
  ,                                       !- Volume {m3}
Zone,
  0,                                      !- X Origin {m}
  0,                                      !- Y Origin {m}
  0,                                      !- Z Origin {m}
  ,                                       !- Type
  1,                                      !- Multiplier
  ,                                       !- Volume {m3}
Hello everyone,
PEOPLE,
People,
People,
SpaceList,
Space,
  Floor_1,                                !- Name
  ,                                       !- Volume {m3}
Space,
  Floor_2,                                !- Name
  ,                                       !- Volume {m3}
Zone,
  0,                                      !- X Origin {m}
  0,                                      !- Y Origin {m}
  0,                                      !- Z Origin {m}
  ,                                       !- Type
  1,                                      !- Multiplier
  ,                                       !- Volume {m3}
Zone,
  0,                                      !- X Origin {m}
  0,                                      !- Y Origin {m}
  0,                                      !- Z Origin {m}
  ,                                       !- Type
  1,                                      !- Multiplier
  ,                                       !- Volume {m3}
