How can I load custom python packages (pip) without extra arguments
Hello all,
It is possible to load custom python packages in the workflow by calling openstudio like so:
openstudio --python_path /path_to_python_packages run --workflow wkfl.osw
However I'd like to do this without adding the --python_path argument, I've tried a few things
  1. Setting the PYTHONPATH environment variable, this doesn't work for a OpenStudio workflow I believe its something to do with the OpenStudio source code
  2. Using the code in the measure
sys.path.insert(0, '/root/.pyenv/versions/3.12.3/lib/python3.12/site-packages')
where /root/.pyenv/versions/3.12.3/lib/python3.12/site-packages is the path to the custom python packages which we want to use in the measure this does work and I'm inclined to use something like this as a solution
Is there a better way then 2.? Or perhaps I'm missing something here?
I'd also like to ask what is the correct way to load custom python modules into a python measure on the OpenStudio server.
Thank you!
Hello all,
It is possible to load custom python packages in the into a openstudio workflow by calling openstudio like so:
Thank you! you!
Hello all,
It is possible to load custom python packages into a openstudio workflow by calling openstudio like so:
However I'd like to do this without adding the --python_path argument, I've tried a few two things
  1. Setting the PYTHONPATH environment variable, this doesn't work for a OpenStudio workflow I believe its something to do with the OpenStudio source codecode.
  2. Using the code in the measuremeasure like so,
is the path to the custom python packages which we want to use in the measure this measure. This does work and I'm inclined to use something like this as a solution
Thank you!
Hello all,
However I'd like to do this without adding the --python_path argument, I've tried two things
  1. Setting the PYTHONPATH environment variable, this doesn't work for a OpenStudio workflow I believe its something to do with the OpenStudio source code.
  2. Using code in the measure like so,
where
is the path to the custom python packages which we want to use in the measure. This does work and I'm inclined to use something like this as a solution
Thank you!
How can I load custom python packages (pip) without extra OSW arguments
Hello all,
sys.path.insert(0, '/root/.pyenv/versions/3.12.3/lib/python3.12/site-packages')'path_to_custom_python_packages')
where
/root/.pyenv/versions/3.12.3/lib/python3.12/site-packages'path_to_custom_python_packages
Is there a better way then 2.? the above? Or perhaps I'm missing something here?
Thank you!
Hello all,
sys.path.insert(0, 'path_to_custom_python_packages')
where
Is there a better way then the above? Or perhaps I'm missing something here?
Thank you!
