What could cause a measure to run fine in Apply Now but fail in PAT?
I wrote a measure than runs perfectly on the model itself when I use "Apply Now".
But when I run it in PAT, I get an error.
I've been opening the model, and running each of the measures in the same exact order I have in the given package, and it works alright.
Here's the full error log
click to hide/show revision 2
No.2 Revision
Interestingly enough, I used to run the same PAT in 1.7.0 no problem.
Also, in this package, I actually call the measure twice (I have a suffix modifier for the thermal zones to affect), the first one is ok, the second crashes.
