Hi. I'm modeling a simple box and want to get output. I toggled on several variables in the OS, in output variables tab. (e.g., Site Direct Solar Radiation Rate per Arer)
The 'run simulation' was successful, but I don't know where to check the results I toggled on. In the EP, there was a CSV file so I could check output variables(RDD). Where can I find the results in the OS?
I used OS 1.7.2 and EP 23.2 version. The model I used is shown in the attached file.
