VRF system shows very low COP in heating mode
Dear all,
I am modelling a VRF system for a typical office building in Japan (Climate zone 3A). The result indicates that a large proportion of energy goes to heating which is generally not the case in reality.
I exported the Openstudio file to Energyplus and called the hourly COP. I found that the COP for heating is constantly a lot lower (1-1.5)* than the rated COP which I have inputted (3.5)
I am using the default performance curves in Openstudio.
Any ideas what can be done?
*COP <1 has also been observed on some occasions.
Regards, Daniel
Dear all,
I exported the Openstudio file to Energyplus and called the hourly COP. I found that the COP for heating is constantly a lot lower (1-1.5)* (1-1.5) than the rated COP which I have inputted (3.5)(3.5) The COP also appears to reach a max. at around 3.
*COP <1 has also been observed on some occasions.done? image description
Regards, Daniel
Dear all,
I exported the Openstudio file to Energyplus and called the hourly COP. I found that the COP for heating is constantly a lot lower (1-1.5) than the rated COP which I have inputted (3.5) The COP also appears to reach a max. at around 3.
Any ideas what can be done? image description
Regards, Daniel
