Constant COP of Cooling Coil
In EnergyPlus, if I want my cooling system to have a constant COP regardless of temperature or flow fraction, which performance curves should I modify — should I flatten the 'Energy Input Ratio Function of Temperature' and 'Energy Input Ratio Function of Flow Fraction' curves (e.g., set them equal to 1.0), or is there another recommended way to configure the curves for constant COP performance?
