jeplus will not stop simulation after adding rvx item
Hi, everyone! I'm learning energyplus and jeplus by using DOE reference Buildings to do simulation and optimization. Now i meet a problem. When I add any RVX item in result collection then run simulation, the monitor will show 100% completed but program not stop. Once I delete RVX, it can successfully complete simulation. But I want to collect some specific variables for research, can anyone tell me how to solve? I use energyplus25.1 and jeplus 2.2Here is the txt content in json file: { "projectType" : "EPLUS", "projectID" : "G", "projectNotes" : "RetailOpt", "weatherDir" : "D:\Project\Jeplus\RetailOpt\", "weatherFile" : "USA_IL_Chicago-OHare.Intl.AP.725300_TMY3.epw", "idfdir" : "D:\Project\Jeplus\RetailOpt\", "idftemplate" : "RefBldgStand-aloneRetailNew2004_v1.3_5.0_2A_USA_TX_HOUSTONl.imf", "dckdir" : "D:\Project\Jeplus\RetailOpt\", "outputFileNames" : "trnsysout.csv", "parameters" : [ { "paramType" : "PARAMETRICS", "id" : "P0", "name" : "material", "description" : "Construction Type with different thickness", "searchString" : "@@type@@", "type" : "INTEGER", "valuesString" : "[1 :1 :3 ]", "selectedAltValue" : 0 } ], "rvx" : { "notes" : "", "rvis" : [ ], "csvs" : [ { "sourceCsv" : "eplustbl.csv", "fromReport" : "Annual Building Utility Performance Summary", "fromFor" : "Entire Facility", "fromTable" : "Site and Source Energy", "fromColumn" : "Total Energy [GJ]", "fromRow" : "Total Site Energy", "tableName" : "TotalEnergy", "columnHeaders" : "Total Energy [GJ]", "usedInCalc" : true } ], "sqls" : [ ], "scripts" : [ ], "userSupplied" : [ ], "trns" : [ ], "userVars" : [ ], "objectives" : [ ], "constraints" : [ ] }, "execSettings" : { "numThreads" : 24, "workDir" : "D:\Project\Jeplus\RetailOpt\output\", "subSet" : -1, "sampleOpt" : "SHUFFLE", "randomSeed" : 12345, "numberOfJobs" : 81, "jobListFile" : "select job list file ...", "rerunAll" : true, "keepJEPlusFiles" : true, "keepEPlusFiles" : true, "deleteSelectedFiles" : false, "selectedFiles" : "*.dxf *.htm *.mtd *.mdd *.rdd *.shd *.out *.audit *.eio *.idd *.bnd *.ini", "timeout" : 0, "steps" : { "prepareJobs" : true, "collectResults" : true, "jobListFile" : "joblist_out.csv", "runSimulations" : true, "writeJobList" : true } } }
Hi, everyone! I'm learning energyplus and jeplus by using DOE reference Buildings to do simulation and optimization. Now i meet a problem. When I add any RVX item in result collection then run simulation, the monitor will show 100% completed but program not stop. Once I delete RVX, it can successfully complete simulation. But I want to collect some specific variables for research, can anyone tell me how to solve? I use energyplus25.1 and jeplus 2.2Here is the txt content in json file: file:
  "projectID" : "G",
"D:\\Project\\Jeplus\\RetailOpt\\",
  "parameters" : [ {
    "id" : "P0",
    "type" : "INTEGER",
  "rvx" : {
    "notes" : "",
    "rvis" : [ ],
    "csvs" : [ {
      "usedInCalc" : true
    "sqls" : [ ],
    "scripts" : [ ],
    "trns" : [ ],
    "userVars" : [ ],
    "objectives" : [ ],
    "constraints" : [ ]
  "execSettings" : {
    "numThreads" : 24,
"D:\\Project\\Jeplus\\RetailOpt\\output\\",
    "subSet" : -1,
    "rerunAll" : true,
    "timeout" : 0,
    "steps" : {
Thanks
  "projectID" : "G",
  "weatherDir" : "D:\\Project\\Jeplus\\RetailOpt\\",
  "idfdir" : "D:\\Project\\Jeplus\\RetailOpt\\",
  "dckdir" : "D:\\Project\\Jeplus\\RetailOpt\\",
  "parameters" : [ {
    "id" : "P0",
    "type" : "INTEGER",
  "rvx" : {
    "notes" : "",
    "rvis" : [ ],
    "csvs" : [ {
      "usedInCalc" : true
    "sqls" : [ ],
    "scripts" : [ ],
    "trns" : [ ],
    "userVars" : [ ],
    "objectives" : [ ],
    "constraints" : [ ]
  "execSettings" : {
    "numThreads" : 24,
    "workDir" : "D:\\Project\\Jeplus\\RetailOpt\\output\\",
    "subSet" : -1,
    "rerunAll" : true,
    "timeout" : 0,
    "steps" : {
Thanks
