OpenStudio 1.6.0 application won’t start via .exe on Windows
Hello,
I’m having an issue with OpenStudio on Windows. The application (openstudioapplication-1.6.0, version 3.6.1) cannot be opened directly by double-clicking the OpenStudio.exe file. When I try, the interface just stays stuck on the loading screen indefinitely.
However, if I open an already saved .osm file, the program launches normally. Is there a known fix or workaround?
Thanks in advance!
Hello,
Thanks in advance!
