Different cooling loads between conventional HVAC and geothermal HVAC?
Hi, I simulating HVAC performance between Conventional HVAC and Geothermal based HVAC system. The cooling load seems to be different in both the case, according to my understanding cooling load should be the same, regardless of the HVAC used because the build parameters are same in both of them. Does anyone know what seems to be the problem? Thank you
Hi, I am using Energy plus for simulating different HVAC for the same building. I simulated HVAC performance between Conventional HVAC and Geothermal based HVAC system. The After simulation, the cooling load seems to be different in both the case, according to my understanding cooling load should be the same, regardless of the HVAC used because the build parameters are same in both of them. Does anyone know what seems to be the problem? Thank you
