HVAC System Configuration with Heat Recovery in OpenStudio
I'm having trouble setting up my HVAC system in OpenStudio. The goal is to simulate a test room in my laboratory with the following HVAC configuration:
A chiller unit with a water-cooled condenser: - Cooling Production: The evaporator of the unit cools a chilled water circuit, capable of supplying water at temperatures as low as 2°C. - Heating Production (Heat Recovery): The condenser of the unit recovers the heat absorbed by the evaporator and transfers it to a hot water circuit, which can reach up to 50°C. - A storage tank (ballon) is planned to store the hot water recovered by the condenser. This tank acts as a thermal accumulator before the heat is distributed.
The Air Handling Unit (AHU) serves as the interface between the conditioned water circuits and the test room environment: - It is equipped with a cooling coil (supplied by the chilled water from the buffer tank) and a heating coil (supplied by the hot water from the hot buffer tank). - The AHU manages air renewal (mechanical ventilation) by introducing fresh outdoor air, treating it (cooling/heating/dehumidifying), and distributing it evenly throughout the room. - The AHU's heating coil can be supplemented by an electric resistance heater for additional heat supply or for precise temperature control in heating mode.
I have already added a chiller loop, a hot water loop, and a ventilation loop, and connected all three. However, I keep getting an error saying that no thermal zone is connected, even though I have already inserted the thermal zone in the demand side of the ventilation loop. How can I properly configure a system like this?
A chiller unit with a water-cooled condenser: - condenser:
  • Cooling Production: The evaporator of the unit cools a chilled water circuit, capable of supplying water at temperatures as low as 2°C. - 2°C.
  • Heating Production (Heat Recovery): The condenser of the unit recovers the heat absorbed by the evaporator and transfers it to a hot water circuit, which can reach up to 50°C. - 50°C.
  • A storage tank (ballon) is planned to store the hot water recovered by the condenser. This tank acts as a thermal accumulator before the heat is distributed.
The Air Handling Unit (AHU) serves as the interface between the conditioned water circuits and the test room environment: - environment:
  • It is equipped with a cooling coil (supplied by the chilled water from the buffer tank) and a heating coil (supplied by the hot water from the hot buffer tank). - tank).
  • The AHU manages air renewal (mechanical ventilation) by introducing fresh outdoor air, treating it (cooling/heating/dehumidifying), and distributing it evenly throughout the room. - room.
  • The AHU's heating coil can be supplemented by an electric resistance heater for additional heat supply or for precise temperature control in heating mode.
