Hey, I want to model a simple one-zone building with concrete core activation in the ceiling. The supply temperature of the water should be imported (measured data) by constant flow rate. I would try that through schedule.fiele; the heat flow should be calculated through simulation. - Is it possible to implement concrete core activation in EnergyPlus (maybe as a template) – if so, how? - Is the workflow with a schedule:file for importing the measured supply temperature a good way?
Thank you very much!
