Cooling Coil Condensate Collection - results don't appear for Coil:Cooling:DX:TwoSpeed component
I've added a water storage tank to my single speed DX coils and am accurately getting cooling coil condensate volume output variable to export from my results. When I attempt to do the same with the Two speed DX coils within the same model I am not getting an output variables for the two stage components. Does anyone know why this is happening? Is it a bug?
I've added a water storage tank to my single speed DX coils and am accurately getting cooling coil condensate volume output variable to export from my results. When I attempt to do the same with the Two speed DX coils within the same model I am not getting an any output variables at all for the two stage components. Does anyone know why this is happening? Is it a bug?
I've added a water storage tank to my single speed DX coils and am accurately getting cooling coil condensate volume output variable to export from my results. When I attempt to do the same with the Two speed DX coils within the same model I am not getting any output variables at all for the two stage components. Does anyone know why this is happening? Is it a bug?
Cooling Coil Condensate Collection - results don't appear for Coil:Cooling:DX:TwoSpeed componentcomponent in EnergyPlus
I've added a water storage tank to my single speed DX coils and am accurately getting cooling coil condensate volume output variable to export from my results. When I attempt to do the same with the Two speed DX coils within the same model I am not getting any output variables at all for the two stage components. Does anyone know why this is happening? Is it a bug?bug? IDF file can be downloaded here: https://www.dropbox.com/scl/fi/gwb8fsuh2a1effqzdhg44/in_withoutputs-1.idf?rlkey=yjmwmzu3b7u6tqamv8d1pfmvy&st=teru1uw4&dl=0
