I am trying to run panels described in the California Energy Comission Database https://www.energy.ca.gov/media/2367 Most panels produce a fatal crash in EnergyPlus using the OneDiode model. I am using EnergyPlus Version 23.1.0-87ed9199d4
* Severe * EquivalentOneDiode Photovoltaic model failed to find maximum power point * ~~~ * Numerical solver failed trying to take exponential of too large a number
* ~~~ * Check input data in PhotovoltaicPerformance:EquivalentOne-Diode * ~~~ * VV (voltage) = 17.15636 * ~~~ * II (current) = -3335.62140 * Fatal * FUN: EnergyPlus terminates because of numerical problem in EquivalentOne-Diode PV model
...Summary of Errors that led to program termination: ..... Reference severe error count=1
Is this model not maintained anymore? It seems unusable with more modern panels unless I am missing something.
Here are two panel descriptions -> Panel0 works, Panel1 causes the crash.
PhotovoltaicPerformance:EquivalentOne-Diode,
Panel0PhotovoltaicPerformance, ! Name
CrystallineSilicon, ! cell Type
60, ! cells in series
1, ! module area [m2]
0.9, ! tau alpha product
1.12, ! electron bandgap [eV]
1000000, ! shunt resistance [ohms]
9.34, ! short circuit current [A]
38.63, ! open circuit voltage [V]
25, ! reference temperature [C]
1000, ! reference radiation [W/m2]
2.24, ! current at max power
29.84, ! voltage at max power
0.052, ! dIsc/dT
-0.313, ! dVoc/dT
20, ! NOCT ambient temp [C]
47.4, ! NOCT cell temp [C]
800, ! NOCT radiation [W/m2]
30, ! heat loss coeff [W/m2-K]
50000; ! heat capacity [J/K]
Panel1PhotovoltaicPerformance, ! Name
72, ! cells in series
2.14, ! module area [m2]
11.36, ! short circuit current [A]
49.1, ! open circuit voltage [V]
10.67, ! current at max power
40.8, ! voltage at max power
0.062, ! dIsc/dT
-0.313, ! dVoc/dT
45.4, ! NOCT cell temp [C]
