Use joblist-case definition in jePlus with trnsys
Hi everyone,
I need to run a TRNSYS parameter study with jePlus. For every case of building age, orientation, ... I need to provide a random number for the occupance (not combine all building cases with all occupancies). So I want to use the "List of cases" in the execution tab (generating my case-list in Python). when I select my list-fiel and run the console on the right side says: "0 jobs in C:\TRNSYS\DAMOtl\jeplus\joblist_test.csv started ..." while there are many lines / cases in the file. The start of my "joblist_test.csv" is below. Looking to Chapter 9.3 of the Documentation I also tried: - deleting the header line - removing the two file pathes
Advice would be highly appreciated!
Best regards!
(Header and first 2 lines:) '#Job_ID,Weather File, Model File,@@alt@@,@@WINid@@,@@nutzer@@,@@nabs@@,@@mass@@,@@size@@,@@roo@@,@@tga@@,@@vent@@,@@rot@@,@@wet@@,@@ele@@
TR_G-alt_1-Use_0272-Nabs_1-mass_sch-size_080_SoSchu0_roo1_TGA1_vent0_rot045_wetPari,C:\TRNSYS\DAMOtl\jeplus\null,C:\TRNSYS\DAMOtl\jeplus\null,1,300,0272,1,sch,080,1,1,0,45,Pari,75
TR_G-alt_1-Use_0889-Nabs_0-mass_sch-size_100_SoSchu0_roo1_TGA1_vent0_rot315_wetWars,C:\TRNSYS\DAMOtl\jeplus\null,C:\TRNSYS\DAMOtl\jeplus\null,1,300,0889,0,sch,100,1,1,0,315,Wars,130
Hi everyone,
I need to run a TRNSYS parameter study with jePlus. For every case of building age, orientation, ... I need to provide a random number for the occupance (not combine all building cases with all occupancies). So I want to use the "List of cases" in the execution tab (generating my case-list in Python). when I select my list-fiel and run the console on the right side says: "0 jobs in C:\TRNSYS\DAMOtl\jeplus\joblist_test.csv started ..." while there are many lines / cases in the file. The start of my "joblist_test.csv" is below. Looking to Chapter 9.3 of the Documentation I also tried: - tried:
  • deleting the header line - line
  • removing the two file pathes
Best regards!
Hi everyone,
Best regards!
Hi everyone,
Best regards!
