I created a base model using OpenStudio 1.8.0 and exported the IDF file for use in jEPlus. When simulating the base model in OpenStudio, the eplustbl.htm file was generated successfully, but no eplustbl.csv file was created. I then ran a parametric analysis in jEPlus, where the .csv output file was generated. However, the output table only includes the input combinations of decision variables (Orientation, Heating Setpoint, Cooling Setpoint), while the output fields (Heating Load, Cooling Load, Thermal Discomfort Hours) are completely empty. Note that the eplustbl.htm was generated for each run and the results were there in the html file.
Has anyone faced a similar issue? What could be causing the output fields to be missing, even though simulations seem to run?
